[GRASS-dev] winGRASS OSGeo4W crashes when switching to 3D view
Anna Petrášová
kratochanna at gmail.com
Tue Dec 29 08:20:10 PST 2015
it crashes because it can't allocate enough memory. There must be some
limit given by the operating system how much memory it can allocate
(altogether and by chunks). I assume the 64-bit version could help with
this.
If you run
m.nviz.image elevation_map=elevation output=xxx format=ppm size=640,480
with large regions, you will get:
Loading raster map <elevation at PERMANENT>...
Current region rows: 13500, cols: 15000
ERROR: G_malloc: unable to allocate 810000000 bytes of memory
Anna
On Mon, Dec 28, 2015 at 4:25 AM, Helmut Kudrnovsky <hellik at web.de> wrote:
> Markus Neteler wrote
> > Hi,
> > while teaching our IRSAE course
> > (http://gis.cri.fmach.it/grass-gis-and-r-course/) we did not have
> > success to perform a NVIZ exercise on Windows.
> > Switching to 3D mode leads to a GUI crash when loading the "elevation"
> > DEM. We used "elevation" in the new (yet to be improved) Piemont
> > location [1].
> > No error message shown, just crash.
> > If anyone wants to test:
> > wget http://geodati.fmach.it/gfoss_geodata/grassdata_course_version1.7z
> > # unpack (7a is contained eg in p7zip-plugins package):
> > 7z x grassdata_course_version1.7z
> > --> grassdata_piemonte/user1
> > Note: It is a new issue since 7.0.1, in 7.0.0 which is installed on
> > the same machine no such issue.
> > I suspect that it is the elevation map size causing the issue since
> > the DEM is larger than that of the NC dataset.
> > Markus
> I confirm this. in large regions, 3D view crashes.
> tested here with
> System Info
> GRASS Version: 7.0.2
> and
> System Info
> GRASS Version: 7.1.svn
> and the piemonte data set (but also with other large rasters):
> g.region -p -a raster=elevation at PERMANENT align=elevation at PERMANENT
> projection: 1 (UTM)
> zone: 32
> datum: wgs84
> ellipsoid: wgs84
> north: 5146000
> south: 4879500
> west: 313000
> east: 517000
> nsres: 25
> ewres: 25
> rows: 10660
> cols: 8160
> cells: 86985600
> attached a debug=3 output ( wxnviz_debug.txt
> <http://osgeo-org.1560.x6.nabble.com/file/n5243063/wxnviz_debug.txt> )
> best regards
> Helmut
> http://osgeo-org.1560.x6.nabble.com/winGRASS-OSGeo4W-crashes-when-switching-to-3D-view-tp5243039p5243063.html
> Sent from the Grass - Dev mailing list archive at Nabble.com.
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20151229/a703746b/attachment.html>
