[GRASS-dev] [GRASS GIS] #2660: r.external / r.external.out: support paths relative to the mapset, and variables
trac at osgeo.org
Tue Dec 29 09:58:02 PST 2015
variables
Reporter: sbl | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.3
Component: Raster | Version: svn-releasebranch70
Resolution: | Keywords: r.external.out
CPU: Unspecified | Platform: Unspecified
Comment (by sbl):
Thanks for looking into this!
Let`s say my GRASS DB is /grassdata/LOCATION/MAPSET and my external data
is on /raw_data/...
The Windows equivalent is R:\grassdata\LOCATION\MAPSET and R:\raw_data\...
(let`s assume storage areas are mounted equally on Windows and Linux
(meaning in particular Windows`s drive letters do not change).
If one was able to store the links relative to the current mapset, like
this
../../../raw_data/my_time_series/lots_of_maps.tif
Then the path would be identical for both Windows and Linux, if the code
or link storage could handle the directory separators OS dependent. In the
given example the data would be outside the GRASS DB.
If current behavior should not be changed, maybe a new flag "store link
relative to current mapset" could be added?
P.S.: Sorry for not being precise in my first post. I was actually
thinking of the GRASS variables GISDBASE, LOCATION, MAPSET.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2660#comment:7>
