[GRASS-dev] Mac OS X 10.10 , grass71-svn - fail to start
epi
massimodisasha at gmail.com
Thu Feb 5 20:53:55 PST 2015
Thanks Anna!
it was my fault. a typo in my bash_profile, my GISBASE was pointing to $GISBASE/lib.
Massimo.
> On Feb 5, 2015, at 11:35 PM, Anna Petrášová <kratochanna at gmail.com> wrote:
> On Thu, Feb 5, 2015 at 9:04 PM, epi <massimodisasha at gmail.com <mailto:massimodisasha at gmail.com>> wrote:
> Hi Devs,
> i updated my grass-svn installation, the build ends without errors but trying to start grass i got the following error :
> epimac:~ epi$ grass71
> Cleaning up temporary files...
> Traceback (most recent call last):
> File "/usr/local/bin/grass71", line 1387, in <module>
> clean_temp()
> File "/usr/local/bin/grass71", line 1170, in clean_temp
> call([gfile("etc", "clean_temp")], stdout=nul, stderr=nul)
> File "/usr/local/bin/grass71", line 155, in call
> return subprocess.call(cmd, **kwargs)
> File "/usr/local/Cellar/python/2.7.9/Frameworks/Python.framework/Versions/2.7/lib/python2.7/subprocess.py", line 522, in call
> return Popen(*popenargs, **kwargs).wait()
> File "/usr/local/Cellar/python/2.7.9/Frameworks/Python.framework/Versions/2.7/lib/python2.7/subprocess.py", line 710, in __init__
> errread, errwrite)
> File "/usr/local/Cellar/python/2.7.9/Frameworks/Python.framework/Versions/2.7/lib/python2.7/subprocess.py", line 1335, in _execute_child
> raise child_exception
> OSError: [Errno 2] No such file or directory
> epimac:~ epi$
> it calls binary clean_temp but it can't find it, do you have a file etc/clean_temp? In the source code clean_temp.c is in lib/init.
> Anna
> I don’t know what’s going on, it is possible that is my system that’s broken … and not grass
> thanks for any help in debugging this issue.
> Massimo.
> grass-dev mailing list
> grass-dev at lists.osgeo.org <mailto:grass-dev at lists.osgeo.org>
> http://lists.osgeo.org/mailman/listinfo/grass-dev <http://lists.osgeo.org/mailman/listinfo/grass-dev>
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150205/0b7b919a/attachment.html>
