[GRASS-dev] [GRASS-user] generalize polygons including holes
Markus Metz markus.metz.giswork at gmail.com
Fri Feb 6 02:05:59 PST 2015
On Fri, Feb 6, 2015 at 10:23 AM, Moritz Lennert
<mlennert at club.worldonline.be> wrote:
> [taking this over to grass-dev]
> On 05/02/15 18:23, Markus Metz wrote:
>> On Thu, Feb 5, 2015 at 4:56 PM, Moritz Lennert
>>> On 05/02/15 14:49, Markus Metz wrote:
>>>> On Thu, Feb 5, 2015 at 11:50 AM, Moritz Lennert
>>>>> On 05/02/15 10:06, Markus Metz wrote:
>>>>>> v.generalize does not distinguish between outer and inner rings, it
>>>>>> simply goes through all boundaries and generalizes each one.
>>>>> And this has always been the case or this is specific to GRASS7 ?
>>>> This has always been the case.
>>> Then why doesn't there seem to be any generalization happening for the
>>> hole
>>> boundaries of the test dataset with grass64release ?
>> With the test dataset you provided, GRASS 6.4 does generalize the hole
>> boundaries. I do not have the problem vector of Robert, so I can not
>> say if the hole boundaries in that vector are generalized or not.
> With a make distleaned, svn updated and recompiled grass64relase, using the
> test data and the commands
> v.generalize test method=douglas thresh=100 out=test_gen_100 --o
> v.generalize test method=douglas thresh=500 out=test_gen_500 --o
> I get the attached result (red = 100, orange=500). I don't see any
> generalization in the holes as I do with the same commands in GRASS 7.
Hmm, I do get generalization of the holes in G64 (no local changes).
g.version -g
version=6.4.5svn
revision=64438M
date=2015
black: original, red: thresh=100, green: thresh=500
Markus M
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150206/f48e8a90/attachment.png>
