[GRASS-dev] [GRASS-SVN] r64407 - grass/trunk/gui/wxpython
Anna Petrášová kratochanna at gmail.com
Fri Feb 6 07:21:15 PST 2015
On Fri, Feb 6, 2015 at 9:08 AM, Markus Neteler <neteler at osgeo.org> wrote:
> On Fri, Feb 6, 2015 at 2:07 PM, Martin Landa <landa.martin at gmail.com>
> wrote:
> > Hi,
> > 2015-02-03 3:08 GMT+01:00  <svn_grass at osgeo.org>:
> >> Author: wenzeslaus
> >> Date: 2015-02-02 18:08:29 -0800 (Mon, 02 Feb 2015)
> >> New Revision: 64407
> >> Modified:
> >>    grass/trunk/gui/wxpython/gis_set.py
> >> Log:
> >> wxGUI/startup: make warnings, hints and infos show the same; number
> boxes
> > thanks for improvements, unfortunately the window is behaving strange
> > when resizing. When I enlarge original screen (grass71_welcome.png)
> > and than resize to minimum size I get (grass71_welcome_resized.png).
> > It seems to be related only to wxPython 3.0 (tested on GNU/Linux). It
> > works perfectly with wxPython 2.8.
I can confirm that. I looked at that but so far nothing.
Anna
> I checked here with
> GRASS 7.1.svn (eu_laea):~ > g.version -ge
> version=7.1.svn
> date=2015
> revision=64482
> build_date=2015-01-06
> build_platform=x86_64-unknown-linux-gnu
> proj4=4.8.0
> gdal=1.11.1
> geos=3.4.2
> sqlite=3.8.8
> rpm -qa | grep wxPython
> wxPython-2.8.12.0-8.fc21.x86_64
> and all is fine (just to confirm).
> I dunno at which stage the wxPython 3 integration is in Fedora:
> https://fedoraproject.org/wiki/Changes/wxPython3
> Perhaps there is a docker image around for quick testing?
> Markus
> grass-commit mailing list
> grass-commit at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-commit
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150206/2b87b2a6/attachment.html>
