[GRASS-dev] G71 errors at startup
Margherita Di Leo diregola at gmail.com
Mon Feb 9 06:03:56 PST 2015
just updated GRASS 7.1.svn (r64526), (after make clean, make distclean, svn
up etc..)
At start up I get the following:
r.area: Unable to fetch interface description for command 'r.area'.
Details: ERROR: Module built against version $Revision: 59317 $ but trying
to use
       version $Revision: 63930 $. You need to rebuild GRASS GIS or
       untangle multiple installations.
r.regression.series: Unable to fetch interface description for command
'r.regression.series'.
Details: ERROR: Module built against version $Revision: 60387 $ but trying
to use
r.stream.basins: Unable to fetch interface description for command
'r.stream.basins'.
to use
r.stream.order: Unable to fetch interface description for command
'r.stream.order'.
Details: ERROR: Module built against version $Revision: 62060 $ but trying
to use
r.stream.snap: Unable to fetch interface description for command
'r.stream.snap'.
to use
r.stream.stats: Unable to fetch interface description for command
'r.stream.stats'.
to use
wx.metadata: Unable to fetch interface description for command
'wx.metadata'.
Details: [Errno 2] No such file or directory
Best regards,
Dr. Margherita DI LEO
Scientific / technical project officer
European Commission - DG JRC
Institute for Environment and Sustainability (IES)
Via Fermi, 2749
I-21027 Ispra (VA) - Italy - TP 261
Tel. +39 0332 78 3600
margherita.di-leo at jrc.ec.europa.eu
Disclaimer: The views expressed are purely those of the writer and may not
in any circumstance be regarded as stating an official position of the
European Commission.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150209/87b8e8cc/attachment.html>
