[GRASS-dev] [GRASS GIS] #2584: Vectors skipping columns (character limit !!!) while exporting to OGR data
GRASS GIS trac at osgeo.org
Tue Feb 10 09:13:49 PST 2015
 Reporter:  spareeth        |       Owner:  grass-dev@…
     Type:  defect          |      Status:  new
 Priority:  normal          |   Milestone:  7.0.0
Component:  LibVector       |     Version:  svn-trunk
 Keywords:  OGR, shapefile  |    Platform:  Linux
      Cpu:  Unspecified     |
 Hi
 I am trying to export a vector data with many columns to shape format. But
 it seems it is avoiding all the columns with greater than 10 characters
 (from the pattern, not sure). Tried in GRASS 6.4.5, GRASS 7.0 svn and
 GRASS 7.1 svn, giving the same error.
 Please find attached the packed vector layer which i tried.
 v.out.ogr input=test output=test_output.shp
 gives me following error, but finishes the job with remaining columns.
 ERROR 6: Failed to add field named 'int_minimum'
 ERROR 6: Failed to add field named 'int_maximum'
 ERROR 6: Failed to add field named 'int_average'
 ERROR 6: Failed to add field named 'int_variance'
 ERROR 6: Failed to add field named 'int_coeff_var'
 ERROR 6: Failed to add field named 'int_first_quartile'
 ERROR 6: Failed to add field named 'int_third_quartile'
 ERROR 6: Failed to add field named 'int_percentile_90'
 Regards
 Sajid
Ticket URL: <http://trac.osgeo.org/grass/ticket/2584>
