[GRASS-dev] NVIZ broken in GRASS 7.0 RC2
Michael Barton Michael.Barton at asu.edu
Tue Feb 10 19:46:44 PST 2015
Maybe. I just looked at the code and I agree that it looks OK.
The problem seems to be somewhere in
 def _createSurfacePage(self, parent):
The ‘selection’ (map selection for surfaces) part seems fine and it is possible to select a map. But the remaining widgets don’t work (e.g. ‘draw’, ‘mode’, etc).
The change sets you reference are not in the section where the SurfacePage and its controls are defined. Hopefully, these have something to do with with it anyway and you can find out what is the problem.
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Head, Graduate Faculty in Complex Adaptive Systems Science
Arizona State University
voice:  480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax: 480-965-7671 (SHESC),  480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Feb 10, 2015, at 5:27 PM, Anna Petrášová <kratochanna at gmail.com<mailto:kratochanna at gmail.com>> wrote:
On Tue, Feb 10, 2015 at 6:50 PM, Michael Barton <Michael.Barton at asu.edu<mailto:Michael.Barton at asu.edu>> wrote:
I just compiled RC2 today for the Mac.
The NVIZ control panels have been redesigned to use staticbox containers. But these have not been defined in the correct order with their contents. So mouse clicks do not register.  This is probably a simple fix. But I can’t post the broken binaries.
I don't understand, there has been no such change.  But I suspect this one
http://trac.osgeo.org/grass/changeset/64299/grass/branches/releasebranch_7_0/gui/wxpython/nviz/tools.py
you can try to see if this is the revision when it stopped working. I will try to get access to a Mac to fix it.
Anna
Michael
C. Michael Barton
voice:  480-965-6262<tel:480-965-6262> (SHESC), 480-965-8130<tel:480-965-8130>/727-9746 (CSDC)
fax: 480-965-7671<tel:480-965-7671> (SHESC),  480-727-0709<tel:480-727-0709> (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu<http://csdc.asu.edu/>
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150211/190beec5/attachment.html>
