[GRASS-dev] NVIZ broken in GRASS 7.0 RC2
Anna Petrášová kratochanna at gmail.com
Wed Feb 11 09:05:36 PST 2015
On Tue, Feb 10, 2015 at 10:46 PM, Michael Barton <Michael.Barton at asu.edu>
wrote:
>  Maybe. I just looked at the code and I agree that it looks OK.
>  The problem seems to be somewhere in
>   def _createSurfacePage(self, parent):
>  The ‘selection’ (map selection for surfaces) part seems fine and it is
> possible to select a map. But the remaining widgets don’t work (e.g.
> ‘draw’, ‘mode’, etc).
>  The change sets you reference are not in the section where the
> SurfacePage and its controls are defined. Hopefully, these have something
> to do with with it anyway and you can find out what is the problem.
I reverted the previous change which was fixing a problem on Windows. The
problem there is initialization, where on each system the initialization
events behave differently and I would need more time to rewrite it.
I also removed all progressbar calls on Mac in nviz, because I was getting
some recursion problems which were slowing down the gui. I don't really
have time for proper fix (if there is any).
Could you test this change (r64564), if you can see any improvement so that
I can backport it?
Anna
> Michael
>             ____________________
>  C. Michael Barton
>  Director, Center for Social Dynamics & Complexity
>  Professor of Anthropology, School of Human Evolution & Social Change
> Head, Graduate Faculty in Complex Adaptive Systems Science
>  Arizona State University
>  voice:  480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
> fax: 480-965-7671 (SHESC),  480-727-0709 (CSDC)
>  www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
>  On Feb 10, 2015, at 5:27 PM, Anna Petrášová <kratochanna at gmail.com>
> wrote:
> On Tue, Feb 10, 2015 at 6:50 PM, Michael Barton <Michael.Barton at asu.edu>
> wrote:
>> I just compiled RC2 today for the Mac.
>>  The NVIZ control panels have been redesigned to use staticbox
>> containers. But these have not been defined in the correct order with their
>> contents. So mouse clicks do not register.  This is probably a simple fix.
>> But I can’t post the broken binaries.
>  I don't understand, there has been no such change.  But I suspect this
> one
> http://trac.osgeo.org/grass/changeset/64299/grass/branches/releasebranch_7_0/gui/wxpython/nviz/tools.py
>  you can try to see if this is the revision when it stopped working. I
> will try to get access to a Mac to fix it.
>  Anna
>>  Michael
>>  C. Michael Barton
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150211/37b3e7bf/attachment-0001.html>
