[GRASS-dev] [GRASS GIS] #2534: i.segment.hierarchical install error
Javier Martínez-López javi.martinez.lopez at gmail.com
Fri Feb 13 10:44:25 PST 2015
I have the same issue in GRASS 7.1 revision: 63930 under Fedora linux
21, is it possible to go around this problem? when I clone the add on
folder (from github) on my scripts folder and run make, it does not
work either (see below). Thank you and cheers, Javier
[javier at localhost i.segment.hierarchical]$ make
Makefile:17: warning: overriding recipe for target
'/usr/local/grass-7.1.svn/etc/i.segment.hierarchical'
../../include/Make/ScriptRules.make:19: warning: ignoring old recipe
for target '/usr/local/grass-7.1.svn/etc/i.segment.hierarchical'
if [ "/usr/local/grass-7.1.svn/scripts/i.segment.hierarchical" != "" ]
; then GISRC=/usr/local/grass-7.1.svn/demolocation/.grassrc71
GISBASE=/usr/local/grass-7.1.svn
PATH="/usr/local/grass-7.1.svn/bin:/usr/local/grass-7.1.svn/bin:/usr/local/grass-7.1.svn/scripts:$PATH"
PYTHONPATH="/usr/local/grass-7.1.svn/etc/python:/usr/local/grass-7.1.svn/gui/wxpython:$PYTHONPATH"
LD_LIBRARY_PATH="/usr/local/grass-7.1.svn/bin:/usr/local/grass-7.1.svn/scripts:/usr/local/grass-7.1.svn/lib:/usr/local/grass-7.1.svn/lib:"
LC_ALL=C /usr/local/grass-7.1.svn/scripts/i.segment.hierarchical
--html-description < /dev/null | grep -v '</body>\|</html>' >
i.segment.hierarchical.tmp.html ; fi
/bin/sh: /usr/local/grass-7.1.svn/scripts/i.segment.hierarchical: Es
un directorio
../../include/Make/Html.make:14: recipe for target
'i.segment.hierarchical.tmp.html' failed
make: *** [i.segment.hierarchical.tmp.html] Error 1
rm i.segment.hierarchical.tmp.html
>  Reporter:  dnewcomb                |       Owner:  grass-dev at ...
>      Type:  defect                  |      Status:  new
>  Priority:  normal                  |   Milestone:  7.0.0
> Component:  Addons                  |     Version:  svn-releasebranch70
>  Keywords:  i.segment.hierarchical  |    Platform:  Linux
>       Cpu:  x86-64                  |
> Comment(by mlennert):
>  Replying to [comment:3 dnewcomb]:
>  > Replying to [comment:2 mlennert]:
>  > > see also #2480, seems to be the same issue.
>  > > Moritz
>  > Interesting, i.segment.gsoc installed without a problem.
>  That's a C-Module so different make logic. (And AFAIK it's actually
>  superseded by i.segment in core).
>  Moritz
> Ticket URL: <http://trac.osgeo.org/grass/ticket/2534#comment:4>
> GRASS GIS <http://grass.osgeo.org>
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
