[GRASS-dev] [GRASS GIS] #2534: i.segment.hierarchical install error
Markus Neteler neteler at osgeo.org
Sat Feb 14 03:36:10 PST 2015
On Fri, Feb 13, 2015 at 7:44 PM, Javier Martínez-López
<javi.martinez.lopez at gmail.com> wrote:
> I have the same issue in GRASS 7.1 revision: 63930 under Fedora linux
> 21, is it possible to go around this problem?
Sure (I'm also on Fedora) but this is vali for any Linux distro
you need to specify where your GRASS GIS sources are:
e.g.:
make MODULE_TOPDIR=$HOME/software/grass71
then it compiles fine.
Markus
