[GRASS-dev] [GRASS GIS] #1075: Better default values in GUI function
trac at osgeo.org
Sat Feb 14 16:46:02 PST 2015
Reporter: vesnikos | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: minor | Milestone: 7.0.0
Component: wxGUI | Version: svn-trunk
Keywords: forms, module defaults | Platform: All
Cpu: All |
Changes (by wenzeslaus):
* keywords: => forms, module defaults
Comment:
Replying to [ticket:1075 vesnikos]:
> what Im proposing, is that the gui should recommended (or autofill) some
optional or required fields that the user needs to fill. For example the
proposed name of an output file/layer could be
`${input_name)_${command_called}_${region}`.
This makes sense to me. It is probably possible to implement without much
side effects, although that's hard for the code in `forms.py`. Generating
the new name can be a bit tricky: Some modules have more outputs, e.g.
`r.slope.aspect`, so you have to find out, what are the output options and
if there is more then one, include also the name of the option. I'm not
sure about the region, details are part of the map metadata (e.g.
`r.info`). It would be good to think about different cases before
implementing anything like that.
> The same can said for some arithmetic values.
These as well as other defaults should be solved at the level of modules.
If you have some ideas, please suggest them individually for a given
module.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1075#comment:1>
