[GRASS-dev] [GRASS GIS] #886: improve module wxGUI tab logic
trac at osgeo.org
Sat Feb 14 17:00:47 PST 2015
Reporter: hamish | Owner: grass-dev@…
Type: enhancement | Status: closed
Priority: normal | Milestone: 7.0.0
Component: wxGUI | Version: svn-trunk
Resolution: fixed | Keywords: tabs, forms
Platform: All | Cpu: All
Changes (by wenzeslaus):
* keywords: tabs => tabs, forms
* status: new => closed
* resolution: => fixed
Comment:
Currently, you can have required items on other tabs if you specify the
`guisection`. The required items are marked using red star. I consider
this as fixing the ticket. Current state is quite satisfactory, but open a
new ticket if there are some improvements which could be done.
Optional is still Optional, not Others. It might be better to have Other
but perhaps it should be Others if there is no Optional but this starts to
be complicated. Please, open a new ticket or write to the mailing list to
discuss it.
Ticket URL: <http://trac.osgeo.org/grass/ticket/886#comment:12>
