[GRASS-dev] Consistency in raster file's history produced with t.rast.series
Nikos Alexandris
nik at nikosalexandris.net
Wed Feb 18 02:07:38 PST 2015
Thanks for the feedback Soeren,
Nikos
On 18.02.2015 11:42, Sören Gebbert wrote:
> Hi Nikos,
> 2015-02-18 10:36 GMT+01:00 Nikos Alexandris
> <nik at nikosalexandris.net>:
>> The following works just fine:
>> t.rast.series ols output=ols_max method=maximum
>> But the history isn't exactly consistent:
>> r.info ols_max -h
>> Data Description:
>> generated by r.series
>> Comments:
>> r.series -z file="/geo/grassdb/ols/sicily/.tmp/tpx1c2g/22707.0"
>> outp\
>> ut="ols_max" method="maximum"
>> Why not record that the raster map in question was produced by
>> t.rast.series? Is it not desired?
> It is not implemented and i have no plan to do so.
> Only temporal datatypes (STDS) will have their own temporal framework
> specific command history. Several temporal modules are simple wrapper
> around existing spatial modules, hence the command history will
> reflect the wrapped module calls.
> Best regards
> Soeren
