Hi, creating a map with t.rast.series ols output=ols_sum method=sum gives the map which is listed normally via 1) g.list rast & 2) t.list rast Removing the map via g.remove rast name=ols_sum -f is not reflected in t.list rast Shouldn't this be updated in tgis' data base? Thanks, Nikos
