[GRASS-dev] Removed raster produced by t.rast.series still in t.list rast
Sören Gebbert soerengebbert at googlemail.com
Wed Feb 18 02:27:06 PST 2015
Hi Nikos,
2015-02-18 10:58 GMT+01:00 Nikos Alexandris <nik at nikosalexandris.net>:
> Hi,
> creating a map with
> t.rast.series ols output=ols_sum method=sum
> gives the map which is listed normally via
> 1) g.list rast  &  2) t.list rast
> Removing the map via
> g.remove rast name=ols_sum -f
> is not reflected in t.list rast
> Shouldn't this be updated in tgis' data base?
Only temporal commands can update the temporal database.
The module g.remove does not know anything about the temporal framework,
hence g.remove and all other general/spatial commands are unable to
Implementing temporal database management in the existing C modules is
tricky, since
the temporal framework is implemented in Python. More critical is,
that many temporal modules
use spatial and general modules in their processing task. Hence, there
are problems regarding recursion, performance and concurrent temporal
database read/write access.
Which module should unregister map layer in case they get overwritten
within the temporal module? The temporal module that was called or the
spatial module that was used by the temporal module?
How does a spatial module know when to unregister a map from the
temporal database? Should it do it
always, or only when it is not called from a temporal module? The
temporal modules will try to gather all the information about
overwritten, registered and unregistered map layers and perform the
temporal management tasks (register, unregister, update, ...) much,
much more efficient then multiple single spatial module calls.
Hence, it is a design decision regarding performance with the drawback
of more user responsibility about data handling.
As a result you need to use t.unregister to manually unregister the map from the
temporal database.
> Thanks, Nikos
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
