[GRASS-dev] Removed raster produced by t.rast.series still in t.list rast
Nikos Alexandris
nik at nikosalexandris.net
Wed Feb 18 03:03:25 PST 2015
Sören Gebbert wrote:
> be aware that t.rast.series will only attach a time stamp to the
> resulting raster map (that means it will put it into the temporal
> database as a time stamped map layer), but it will to register it in
> any space time raster dataset. Hence, use t.unregister without the
> input option, since the map is only registered in the temporal
> database but not in a space time raster dataset:
> t.unregister maps=ols_sum
Danke Soeren. Makes sense. Maybe this info can be added in the
manual?
Nikos
