[GRASS-dev] Cannot install BOTH grass 6 AND grass7 stable from Ubuntu repo..
Sebastiaan Couwenberg sebastic at xs4all.nl
Wed Feb 25 12:18:23 PST 2015
On 02/25/2015 09:08 PM, Martin Landa wrote:
> Hi,
> 2015-02-25 21:02 GMT+01:00 Sebastiaan Couwenberg <sebastic at xs4all.nl>:
>> These Conflicts need to be removed from the GRASS upstream packages to
>> allow co-installation of grass & grass7.
> does it mean to remove Conflicts from rules file on Launchpad or?
Yes, you need to remove the Conflicts from the GRASS packaging on
Launchpad to fix this issue.
While you're at it, there are some fixes you need in
grass7-core.links & grass7-core.links.in:
- remove the symlink from grass70 to itself,
  the symlink from grass to grass70 was a cause of conflicts between
  the grass & grass70 packages.
- remove the symlink from grass at VERSION@.1.gz to grass.1.gz,
  grass7-core.links is correct, but grass7-core.links.in is not.
The man pages in grass7-doc.install{,.in} is still a cause of conflict
between the grass & grass7 packages. Instead of use Conflicts to prevent
co-installation with dependencies, using the alternatives system to
switch between version like openjdk-6 & 7 uses is probably better.
Kind Regards,
Bas
 GPG Key ID: 4096R/6750F10AE88D4AF1
Fingerprint: 8182 DE41 7056 408D 6146  50D1 6750 F10A E88D 4AF1
