[GRASS-dev] Cannot install BOTH grass 6 AND grass7 stable from Ubuntu repo..
Martin Landa
landa.martin at gmail.com
Wed Feb 25 12:35:47 PST 2015
2015-02-25 21:18 GMT+01:00 Sebastiaan Couwenberg <sebastic at xs4all.nl>:
> While you're at it, there are some fixes you need in
> grass7-core.links & grass7-core.links.in:
> - remove the symlink from grass70 to itself,
> the symlink from grass to grass70 was a cause of conflicts between
> the grass & grass70 packages.
> - remove the symlink from grass at VERSION@.1.gz to grass.1.gz,
> grass7-core.links is correct, but grass7-core.links.in is not.
I fixed these issues and put to Launchpad the new packages as
`7.0.0-7`. Testing welcomed (the new package should be available in
30min).
> The man pages in grass7-doc.install{,.in} is still a cause of conflict
> between the grass & grass7 packages. Instead of use Conflicts to prevent
> co-installation with dependencies, using the alternatives system to
> switch between version like openjdk-6 & 7 uses is probably better.
This issue is still open. Martin
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
