[GRASS-dev] [GRASS-SVN] r63924 - in grass/branches/releasebranch_7_0/general: g.list g.list/testsuite g.parser g.remove g.remove/testsuite g.setproj g.tempfile
Vaclav Petras
wenzeslaus at gmail.com
Fri Jan 2 06:34:47 PST 2015
On Thu, Jan 1, 2015 at 5:49 PM, <svn_grass at osgeo.org> wrote:
> Author: neteler
> Date: 2015-01-01 14:49:11 -0800 (Thu, 01 Jan 2015)
> New Revision: 63924
> Added:
> grass/branches/releasebranch_7_0/general/g.list/testsuite/
> grass/branches/releasebranch_7_0/general/g.list/testsuite/test_g_list.py
> grass/branches/releasebranch_7_0/general/g.remove/testsuite/
> grass/branches/releasebranch_7_0/general/g.remove/testsuite/test_g_remove.py
Just to be sure that we know what we are doing. Are you planning to
backport gunittest? These tests are useless without it. If you just want to
reduce differences when using Meld then it is much more efficient to create
a file filter (Edit > Preferences > File Filters) in Meld. For example, I
have one named GRASS GIS which has OBJ.* bin.* dist.* in the pattern. You
can quickly turn on and off the filters in toolbar using Filters.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150102/d6bc2a82/attachment-0001.html>
