[GRASS-dev] [GRASS-SVN] r63924 - in grass/branches/releasebranch_7_0/general: g.list g.list/testsuite g.parser g.remove g.remove/testsuite g.setproj g.tempfile
Markus Neteler
neteler at osgeo.org
Sun Jan 4 13:31:58 PST 2015
On Fri, Jan 2, 2015 at 3:34 PM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> On Thu, Jan 1, 2015 at 5:49 PM, <svn_grass at osgeo.org> wrote:
>> Author: neteler
>> Date: 2015-01-01 14:49:11 -0800 (Thu, 01 Jan 2015)
>> New Revision: 63924
>> Added:
>> grass/branches/releasebranch_7_0/general/g.list/testsuite/
>> grass/branches/releasebranch_7_0/general/g.list/testsuite/test_g_list.py
>> grass/branches/releasebranch_7_0/general/g.remove/testsuite/
>> grass/branches/releasebranch_7_0/general/g.remove/testsuite/test_g_remove.py
> Just to be sure that we know what we are doing. Are you planning to backport
> gunittest?
The test suite should definitely be backported in the near future
(perhaps not for 7.0.0).
> These tests are useless without it. If you just want to reduce
> differences when using Meld then it is much more efficient to create a file
> filter (Edit > Preferences > File Filters) in Meld. For example, I have one
> named GRASS GIS which has OBJ.* bin.* dist.* in the pattern. You can quickly
> turn on and off the filters in toolbar using Filters.
ok.
Markus
