[GRASS-dev] [GRASS GIS] #2523: wxGUI digitiser - GRASS 7.0.0beta4
GRASS GIS trac at osgeo.org
Fri Jan 2 11:43:28 PST 2015
 Reporter:  jeir       |       Owner:  grass-dev@…
     Type:  defect     |      Status:  new
 Priority:  normal     |   Milestone:  7.0.0
Component:  wxGUI      |     Version:  svn-releasebranch70
 Keywords:  digitizer  |    Platform:  MacOSX
      Cpu:  OSX/Intel  |
Comment(by jeir):
 Tried Michael Barton's 7.1 svn:
 GRASS 7.1.svn (r63881M)
 Select Vector digitizer option in Map Display Window
 Select roadsmajor as the map layer to digitize
 - The Quit digitiser icon is not visible
 - Succeeded in moving a vector point (after selecting snap also to vector
 point and adjusting the snap distance)
 Selected 2D View
 - responded yes to Save changes?
 Selected Vector digitizer
 - Digitizer palette does not appear, switching back and forth between
 Layer Manager and Map Display / selecting - deselecting roadsmajor in
 Layer Manager did not bring the digitiser palette to view again. The moved
 point's new position was saved.
 Exit GRTAss and python, restart GRASS, repeat procedure, problem persists.
 I have not compiled myself since version 6.3
Ticket URL: <https://trac.osgeo.org/grass/ticket/2523#comment:3>
