[GRASS-dev] [GRASS GIS] #2523: wxGUI digitiser - GRASS 7.0.0beta4
GRASS GIS trac at osgeo.org
Fri Jan 2 14:20:28 PST 2015
 Reporter:  jeir       |       Owner:  grass-dev@…
     Type:  defect     |      Status:  new
 Priority:  normal     |   Milestone:  7.0.0
Component:  wxGUI      |     Version:  svn-releasebranch70
 Keywords:  digitizer  |    Platform:  MacOSX
      Cpu:  OSX/Intel  |
Comment(by annakrat):
 Replying to [comment:3 jeir]:
 > Tried Michael Barton's 7.1 svn:
 > GRASS 7.1.svn (r63881M)
 > Select Vector digitizer option in Map Display Window
 > Select roadsmajor as the map layer to digitize
 > - The Quit digitiser icon is not visible
 I can see it. Do you have the window wide enough?
 > - Succeeded in moving a vector point (after selecting snap also to
 vector point and adjusting the snap distance)
 > Selected 2D View
 > - responded yes to Save changes?
 > Selected Vector digitizer
 > - Digitizer palette does not appear, switching back and forth between
 Layer Manager and Map Display / selecting - deselecting roadsmajor in
 Layer Manager did not bring the digitiser palette to view again. The moved
 point's new position was saved.
 Confirmed. I will try to look into that. It doesn't happen in release
 branch.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2523#comment:4>
