[GRASS-dev] Addons to Ohloh
Vaclav Petras wenzeslaus at gmail.com
Sat Jan 3 07:36:14 PST 2015
On Wed, Apr 2, 2014 at 1:53 AM, Martin Landa <landa.martin at gmail.com> wrote:
> 2014-04-02 4:24 GMT+02:00 Vaclav Petras <wenzeslaus at gmail.com>:
> > The name would be probably "GRASS GIS Addons". Although, we have some
> > uncertainty about extension/addon/module/... terminology.
> this name make sense to me. Right, we call in wxGUI addons somethimes
> as extensions, this probably confusing.
On Wed, Apr 2, 2014 at 3:55 AM, Markus Neteler <neteler at osgeo.org> wrote:
> I can check if I can link it as subproject to the existing GRASS
registration.
I've finally created the GRASS GIS Addons project at (Black Duck) Open Hub
(former Ohloh) [1].
I've used the proposed name and the whole grass-addons repository.
The GRASS GIS project is not linked in any special way; I don't know about
one. However, both are linked through similar projects because of the
similarity in tags.
All, please rate the project and specify that you are using it, e.g. by
adding it to one of your stacks at Open Hub or just clicking on "I use
this" button.
Developers, if you care about your Open Hub statistics, assign your account
to the contributor or contributors. If you don't care, please add at least
aliases [2] if you have more than one SVN user name so that the general
statistics are not distorted. You can have a look to GRASS GIS project
aliases [3]. Please see also post about unifying contributor names in SVN
[4].
Vaclav
[1] https://www.openhub.net/p/grass_gis_addons
[2] https://www.openhub.net/p/grass_gis_addons/aliases
[3] https://www.openhub.net/p/grass_gis/aliases
[4] http://lists.osgeo.org/pipermail/grass-dev/2014-June/069512.html
Here is the current Open Hub "In a Nutshell" report: GRASS GIS Addons...
has had 4,514 commits made by 82 contributors
representing 320,271 lines of code
is mostly written in C
with an average number of source code comments
has a well established, mature codebase
maintained by a large development team
with increasing Y-O-Y commits
took an estimated 85 years of effort (COCOMO model)
starting with its first commit in December, 2006
ending with its most recent commit 4 days ago
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150103/704049eb/attachment.html>
