[GRASS-dev] [GRASS GIS] #2525: Unable to open sqlite database if path contains non-latin letters
trac at osgeo.org
Sun Jan 4 01:34:11 PST 2015
Reporter: marisn | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 7.0.0
Component: wxGUI | Version: svn-releasebranch70
Keywords: | Platform: MSWindows Vista
Cpu: Unspecified |
Comment(by hellik):
Replying to [comment:2 glynn]:
> Replying to [ticket:2525 marisn]:
> > Seems that any operation touching attribute database fails if path
contains non-latin letter.
> > It is a single instance of a general problem of passing file names as
arguments between GUI and modules.
> Do you have the same problem with filenames other than database files?
E.g. do r.in.* or r.out.* work?
it doesn't work with
r.in.gdal --verbose input=C:\wd\eudata\Māris\test.tif output=testfile
Ticket URL: <http://trac.osgeo.org/grass/ticket/2525#comment:4>
