[GRASS-dev] [GRASS GIS] #2525: Unable to open sqlite database if path contains non-latin letters
GRASS GIS trac at osgeo.org
Mon Jan 5 11:35:01 PST 2015
 Reporter:  marisn       |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  major        |   Milestone:  7.0.0
Component:  wxGUI        |     Version:  svn-releasebranch70
 Keywords:               |    Platform:  MSWindows Vista
      Cpu:  Unspecified  |
Comment(by glynn):
 Replying to [comment:3 hellik]:
   File "C:\OSGeo4W\apps\Python27\lib\encodings\cp1252.py",
 Again, that character doesn't exist in cp1252. This isn't specific to
 GRASS; any portable C code will have exactly the same problems. The only
 way that you can open that file is to use Windows-specific functions (e.g.
 _wfopen() or CreateFileW()). Even passing it as an argument requires using
 wmain() instead of main().
 I'm only interested in whether it works in a locale which uses cp1257. The
 fact that it doesn't work with cp1252 is a "wontfix".
Ticket URL: <http://trac.osgeo.org/grass/ticket/2525#comment:5>
