[GRASS-dev] [GRASS GIS] #2529: v.dissolve only dissolve attribute table but not topology
trac at osgeo.org
Mon Jan 5 04:43:57 PST 2015
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 7.0.0
Component: Vector | Version: unspecified
Keywords: dissolve | Platform: MSWindows Vista
Cpu: x86-32 |
Comment(by hellik):
Replying to [comment:1 neteler]:
> Can you upload the map (v.pack) or generate a reproducible example?
vector attached and produced by:
v.extract input=streams at PERMANENT cats=83348 output=streams_oneline
addon v.transects:
v.transects --verbose input=streams_oneline at user1
output=streams_oneline_quads transect_spacing=100 dleft=50 dright=50
type=area
v.db.addtable map=streams_oneline_quads at user1
v.db.addcolumn map=streams_oneline_quads at user1 columns="dis integer"
v.db.update --verbose map=streams_oneline_quads at user1 layer=1 column=dis
value=1
Ticket URL: <http://trac.osgeo.org/grass/ticket/2529#comment:2>
