[GRASS-dev] [GRASS GIS] #2531: v.parallel: strange output
GRASS GIS trac at osgeo.org
Mon Jan 5 05:13:11 PST 2015
 Reporter:  hellik       |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  major        |   Milestone:  7.1.0
Component:  Vector       |     Version:  svn-trunk
 Keywords:  parallel     |    Platform:  MSWindows Vista
      Cpu:  Unspecified  |
 tested in the nc sample data set
 v.extract input=streams at PERMANENT cats=83348 output=streams_oneline
 v.parallel --verbose input=streams_oneline at user1
 output=streams_oneline_parallel_test distance=100 side=both
 see attached result; is this correct?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2531>
