[GRASS-dev] [GRASS GIS] #2531: v.parallel: strange output
trac at osgeo.org
Mon Jan 5 05:14:32 PST 2015
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 7.1.0
Component: Vector | Version: svn-trunk
Keywords: parallel | Platform: MSWindows Vista
Cpu: Unspecified |
Comment(by hellik):
Replying to [ticket:2531 hellik]:
> tested in the nc sample data set
> v.extract input=streams at PERMANENT cats=83348 output=streams_oneline
> v.parallel --verbose input=streams_oneline at user1
output=streams_oneline_parallel_test distance=100 side=both
> see attached result; is this correct?
tested with
System Info
GRASS Version: 7.1.svn
GRASS SVN Revision: 63945
Erstellungsdatum: 2015-01-04
Build Platform: i686-pc-mingw32
GDAL/OGR: 1.11.1
PROJ.4: 4.8.0
GEOS: 3.4.2
SQLite: 3.7.17
Python: 2.7.4
wxPython: 2.8.12.1
Platform: Windows-Vista-6.0.6002-SP2 (OSGeo4W)
Ticket URL: <http://trac.osgeo.org/grass/ticket/2531#comment:1>
