[GRASS-dev] [GRASS GIS] #2533: module GUIs: selected group not taken into account in created command line
trac at osgeo.org
Mon Jan 5 09:39:05 PST 2015
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 7.0.0
Component: Default | Version: svn-releasebranch70
Keywords: group input | Platform: Unspecified
Cpu: Unspecified |
Using a freshly checked-out and compiled grass7release branch today, I
stumbled across the following problem:
* create a group (and possibly subgroup)
* open a module that requires a group as input (ex: i.gensig, i.maxlik,
i.segment)
* select a group
* check the command line at the bottom of the module GUI: you still see
group=<required> instead of the group=NameOfSelectedGroup
This happens which ever way I start the GUI (wxGUI menu, command line,
etc). I have not found a way to make the module actually run, since the
group entry is required. The only way is to type out everything at the
command line (or the command console).
I have seen this behaviour on Debian Testing and Linux Mint LMDE.
Can anybody confirm this ? It is a quite severe bug that makes the GUIs of
several modules unusable. Could it be linked to the recent changes in
parameter names ?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2533>
