[GRASS-dev] [GRASS GIS] #2532: TypeError: environment can only contain string when launching script on Windows
trac at osgeo.org
Wed Jan 21 20:16:05 PST 2015
Windows
Reporter: annakrat | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Default | Version: svn-trunk
Keywords: encoding | Platform: MSWindows 8
Cpu: Unspecified |
Comment(by glynn):
Replying to [comment:17 annakrat]:
> > That makes sense. But the encoding should ideally be done at a higher
level, at the point that wxGUI "knows" that it's dealing with a unicode
value.
> I am not sure where the higher level is and why str and unicode are
mixed in this case.
Unicode values typically come from wxWidgets, e.g. any text retrieved from
a text field will be a unicode object.
> > I'm wondering if sys.setdefaultencoding("EBCDIC-CP-BE") would work ...
> Why would it? Is it easy to test?
Sorry, that was really just thinking out loud. It wouldn't fix anything,
it would just highlight any remaining implicit conversions.
EBCDIC (used on IBM mainframes) is one of the few encodings which
[b]isn't[/b] compatible (or even mostly-compatible) with ASCII. Setting
the default encoding to EBCDIC would make it obvious when implicit
str<->unicode conversions were being performed, because the results would
be completely wrong (e.g. even A-Z/a-z don't have the same codepoints as
ASCII).
The default encoding can only be set in site.py; site.py deletes the
setdefaultencoding() function from the sys module to prevent the default
encoding from being changed after start-up.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2532#comment:18>
