[GRASS-dev] [GRASS-SVN] r64003 - grass-addons/grass7/vector/v.transects
Markus Neteler
neteler at osgeo.org
Thu Jan 8 11:21:43 PST 2015
Hi Anna,
On Thu, Jan 8, 2015 at 7:19 PM, <svn_grass at osgeo.org> wrote:
> Author: annakrat
> Date: 2015-01-08 10:19:01 -0800 (Thu, 08 Jan 2015)
> New Revision: 64003
> Modified:
> grass-addons/grass7/vector/v.transects/v.transects.html
> grass-addons/grass7/vector/v.transects/v.transects.py
> Log:
> v.transects: add l flag to create transect from the last point
> Modified: grass-addons/grass7/vector/v.transects/v.transects.html
> --- grass-addons/grass7/vector/v.transects/v.transects.html 2015-01-08 18:11:43 UTC (rev 64002)
> +++ grass-addons/grass7/vector/v.transects/v.transects.html 2015-01-08 18:19:01 UTC (rev 64003)
> @@ -3,6 +3,9 @@
> <em>v.transects</em> creates equally spaced geometries along
> input lines. The geometries can be lines or quadrilateral areas. Lines
> and areas are generated to be perpendicular to the input line.
> +By default the last point of each line is not used
> +because the last transect distance would be typically different from the previous once.
> +To create a transect from the last point, use flag <b>-l</b>.
> <h2>NOTES</h2>
> @@ -22,8 +25,8 @@
> Location or the
> <a href="http://courses.ncsu.edu/mea792/common/media/gisdemo.zip">gisdemo (47MB)</a>
> Location.
Just a small question... this is yet another location (never seen
before). How does it differ from
http://trac.osgeo.org/grass/wiki/SampleDataset#Downloadofdraftlocationpackage
-> LOCATION ncarolina_spm_base0.3.1.zip (40MB)
It would be nice to not have more than 2 of NC SPM (better only one).
thanks
Markus
