[GRASS-dev] [GRASS-SVN] r64003 - grass-addons/grass7/vector/v.transects
Anna Petrášová
kratochanna at gmail.com
Thu Jan 8 12:26:46 PST 2015
On Thu, Jan 8, 2015 at 2:21 PM, Markus Neteler <neteler at osgeo.org> wrote:
> Hi Anna,
> On Thu, Jan 8, 2015 at 7:19 PM, <svn_grass at osgeo.org> wrote:
> > Author: annakrat
> > Date: 2015-01-08 10:19:01 -0800 (Thu, 08 Jan 2015)
> > New Revision: 64003
> > Modified:
> > grass-addons/grass7/vector/v.transects/v.transects.html
> > grass-addons/grass7/vector/v.transects/v.transects.py
> > Log:
> > v.transects: add l flag to create transect from the last point
> > Modified: grass-addons/grass7/vector/v.transects/v.transects.html
> > --- grass-addons/grass7/vector/v.transects/v.transects.html
> 2015-01-08 18:11:43 UTC (rev 64002)
> > +++ grass-addons/grass7/vector/v.transects/v.transects.html
> 2015-01-08 18:19:01 UTC (rev 64003)
> > @@ -3,6 +3,9 @@
> > <em>v.transects</em> creates equally spaced geometries along
> > input lines. The geometries can be lines or quadrilateral areas. Lines
> > and areas are generated to be perpendicular to the input line.
> > +By default the last point of each line is not used
> > +because the last transect distance would be typically different from
> the previous once.
> > +To create a transect from the last point, use flag <b>-l</b>.
> > <h2>NOTES</h2>
> > @@ -22,8 +25,8 @@
> > Location or the
> > <a href="http://courses.ncsu.edu/mea792/common/media/gisdemo.zip">gisdemo
> (47MB)</a>
> > Location.
> Just a small question... this is yet another location (never seen
> before). How does it differ from
Not sure but I removed it from there.
> http://trac.osgeo.org/grass/wiki/SampleDataset#Downloadofdraftlocationpackage
> -> LOCATION ncarolina_spm_base0.3.1.zip (40MB)
> It would be nice to not have more than 2 of NC SPM (better only one).
> thanks
> Markus
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150108/7995261a/attachment.html>
