[GRASS-dev] [GRASS GIS] #2537: v.external wxgui wizard: ValueError : need more than 3 values to unpack
trac at osgeo.org
Sat Jan 10 02:23:02 PST 2015
Reporter: mlennert | Owner: martinl
Type: defect | Status: assigned
Priority: normal | Milestone: 7.0.0
Component: wxGUI | Version: svn-trunk
Keywords: v.external postresql | Platform: Linux
Cpu: Unspecified |
Comment(by mlennert):
Replying to [comment:4 martinl]:
> Replying to [comment:3 annakrat]:
> > It's somehow related to http://trac.osgeo.org/grass/changeset/63610
which hasn't been backported. v.external is running in the background and
the code expects 4 columns (`layerName, featureType, projection,
geometryColumn`) but you get only 3.
> I have backport it in r64041.
FYI: it was working in release70 and not in trunk, so I guess by
backporting it will now also not work in release70... I can't check right
now, so this message is meant just to give you a heads up.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2537#comment:6>
