[GRASS-dev] [GRASS GIS] #2537: v.external wxgui wizard: ValueError : need more than 3 values to unpack
GRASS GIS trac at osgeo.org
Mon Jan 12 01:30:07 PST 2015
 Reporter:  mlennert              |       Owner:  martinl
     Type:  defect                |      Status:  assigned
 Priority:  normal                |   Milestone:  7.0.0
Component:  wxGUI                 |     Version:  svn-trunk
 Keywords:  v.external postresql  |    Platform:  Linux
      Cpu:  Unspecified           |
Comment(by mlennert):
 Replying to [comment:6 mlennert]:
 > Replying to [comment:4 martinl]:
 > > Replying to [comment:3 annakrat]:
 > > > It's somehow related to http://trac.osgeo.org/grass/changeset/63610
 which hasn't been backported. v.external is running in the background and
 the code expects 4 columns (`layerName, featureType, projection,
 geometryColumn`) but you get only 3.
 > > I have backport it in r64041.
 > FYI: it was working in release70 and not in trunk, so I guess by
 backporting it will now also not work in release70... I can't check right
 now, so this message is meant just to give you a heads up.
 I can confirm now that v.external does not work for PostgreSQL databases
 in trunk and grass70. v.external -t still gives me the same output.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2537#comment:7>
