[GRASS-dev] [GRASS GIS] #2409: last call for options keys consolidation
trac at osgeo.org
Sun Jan 11 12:46:15 PST 2015
Reporter: martinl | Owner: grass-dev@…
Type: task | Status: new
Priority: blocker | Milestone: 7.0.0
Component: Default | Version: unspecified
Keywords: standardized options | Platform: Unspecified
Cpu: Unspecified |
Comment(by annakrat):
Replying to [comment:183 neteler]:
> The following issues are open (TODO):
> * r.mapcalculator: outfile -> output? (any implications in the wxGUI?)
what is r.mapcalculator?
> * r.param.scape: param -> method?
> * r.walk; percent_memory -> memory?
+1
> Eventually a potential issue in file "lib/gis/renamed_options":
> # r.reclass.area
> r.reclass.area|lesser,greater:value, mode
> --> syntax ok?
I would remove it from there, because the logic of the parameters changed
so you cannot easily map the old name to a new name.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2409#comment:185>
