[GRASS-dev] [GRASS GIS] #2409: last call for options keys consolidation
GRASS GIS trac at osgeo.org
Sun Jan 11 13:17:21 PST 2015
 Reporter:  martinl               |       Owner:  grass-dev@…
     Type:  task                  |      Status:  new
 Priority:  blocker               |   Milestone:  7.0.0
Component:  Default               |     Version:  unspecified
 Keywords:  standardized options  |    Platform:  Unspecified
      Cpu:  Unspecified           |
Comment(by neteler):
 Replying to [comment:184 cmbarton]:
 > Replying to [comment:183 neteler]:
 > >  * r.mapcalculator: outfile -> output? (any implications in the
 wxGUI?)
 > Yes. This will break the GUI map calculator. Why the change? Doesn't the
 map calculator always create a new file?
 I propose the change for consistency. Isn't the result a map rather than a
 file (we use that for eg ASCII file output)? So the parameter name should
 be "output" then.
 Replying to [comment:185 annakrat]:
 > > The following issues are open (TODO):
 wxGUI?)
 > what is r.mapcalculator?
 No idea, I found it in the QGIS processing scripts being used.
 In GRASS, it is here:
 scripts/r.mapcalculator/r.mapcalculator
Ticket URL: <http://trac.osgeo.org/grass/ticket/2409#comment:186>
