Moritz Lennert wrote: > So I guess #2480 and #2534 have to be treated individually on a > case-by-case basis ? What exactly is the issue there? If building them manually works, that suggests a problem with g.extension. -- Glynn Clements <glynn at gclements.plus.com>
