[GRASS-dev] svn merge usage
Vaclav Petras
wenzeslaus at gmail.com
Tue Jan 13 07:47:50 PST 2015
On Tue, Jan 13, 2015 at 8:24 AM, Markus Neteler <neteler at osgeo.org> wrote:
> Hi devs,
> perhaps it is not needed to use "svn merge" for the trivial backports.
> Otherwise we'll end up with pages of rev tags in the relbranch
> shortly.
> I would suggest to only use it in case of substantial changes (be many
> or be important ones).
> svn merge is quite convenient with scripts written by Hamish. Doing it by
hand will make backports even more painful then their are now. There was
some possibility to remove the merge information from the commit, right?
Wouldn't this by satisfactory solution to what you want? (It would be
different with Git...)
Just my 0.02 cents,
> Markus
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150113/7320a8b3/attachment-0001.html>
