[GRASS-dev] [GRASS GIS] #2547: v.report: should report stats even if there is no attribute table (or at least fail more gracefully)
trac at osgeo.org
Tue Jan 13 08:49:29 PST 2015
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Vector | Version: svn-releasebranch70
Keywords: v.report vector_columns attribute table | Platform: Unspecified
Cpu: Unspecified |
Comment(by annakrat):
We shouldn't use `vector_columns` on vector maps without attribute table
linked to the layer. Also, if I understand it correctly, part of the code
was not used at all. I committed a change in r64134, but please test it,
both with and without connection. I was confused from the module because I
don't think I was using it before and the manual page is brief, so it
would be good if someone makes sure my changes make sense.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2547#comment:1>
