[GRASS-dev] [GRASS GIS] #2547: v.report: should report stats even if there is no attribute table (or at least fail more gracefully)
GRASS GIS trac at osgeo.org
Wed Jan 14 01:11:58 PST 2015
 Reporter:  mlennert                                 |       Owner:  grass-dev@…
     Type:  defect                                   |      Status:  new
 Priority:  normal                                   |   Milestone:  7.0.0
Component:  Vector                                   |     Version:  svn-releasebranch70
 Keywords:  v.report vector_columns attribute table  |    Platform:  Unspecified
      Cpu:  Unspecified                              |
Comment(by mlennert):
 Replying to [comment:1 annakrat]:
 > We shouldn't use `vector_columns` on vector maps without attribute table
 linked to the layer. Also, if I understand it correctly, part of the code
 was not used at all. I committed a change in r64134, but please test it,
 both with and without connection. I was confused from the module because I
 don't think I was using it before and the manual page is brief, so it
 would be good if someone makes sure my changes make sense.
 I think your change is a very good way of dealing with the issue and the
 result works as expected, now. Thanks a lot !
 This can probably be backported to relbr7. Leaving the ticket open for
 that.
 Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/2547#comment:2>
