[GRASS-dev] SESSION_MANAGER environment variable not defined
Andy Wickert
wickert at colorado.edu
Tue Jan 13 15:21:15 PST 2015
Hi Markus and Moritz and all,
Moritz -- Unity.
Markus --
Starting GRASS GIS...
_IceTransOpen: Unable to Parse address 1
12:20:02 AM: Debug: Failed to connect to session manager: Could not open
network socket
So the blank "NetworkManager" in Unity is definitely the culprit in my mind.
Andy
Andrew D. Wickert
INSTAAR & Geological Sciences, University of Colorado Boulder
Now at:
Universität Potsdam
Institut für Erd- und Umweltwissenschaften
Haus 29, Rm. 153
Karl-Liebknecht-Str. 24-25
14476 Potsdam-Golm, Deutschland
On Tue, Jan 13, 2015 at 2:29 PM, Moritz Lennert <
mlennert at club.worldonline.be> wrote:
> Are you using Unity ? GNOME ? KDE ? A session over ssh ?
> I'm really no windows management and graphical environment expert, but
> apparently some windows managers do not set this variable.
> Moritz
> On 13/01/15 13:02, Andy Wickert wrote:
>> After the uninstall, I have:
>> Python 2.7.8
>> wxPython 2.8.12.1
>> 'echo $SESSION_MANAGER' returns nothing both inside and outside the
>> GRASS GIS environment in terminal.
>> Andrew D. Wickert
>> Now at:
>> Universität Potsdam
>> Haus 29, Rm. 153
>> On Tue, Jan 13, 2015 at 11:50 AM, Moritz Lennert
>> <mlennert at club.worldonline.be <mailto:mlennert at club.worldonline.be>>
>> wrote:
>> On 13/01/15 11:02, Andy Wickert wrote:
>> Markus, you're a genius! I just tried starting the version of
>> GRASS
>> available on the apt repositories and got this message:
>> awickert at dakib:~$ grass
>> Cleaning up temporary files ...
>> Starting GRASS ...
>> ERROR: wxGUI does not support wxPython 3.0.0.0 yet.
>> Error in GUI startup. If necessary, please
>> report this error to the GRASS developers.
>> Switching to text mode now.
>> Hit RETURN to continue...
>> So I think that what you are saying is that wxPython 3 somehow
>> becomes
>> the default / interferes with GRASS. I did:
>> awickert at dakib:~$ sudo apt-get remove python-wxgtk3.0
>> and now everything works. Well, hopefully my removal of wxPython 3
>> doesn't break something else, so hm, is there a way to ensure
>> that GRASS
>> GIS always looks for wxPython 2?
>> The idea is rather to try to solve any errors concerning wxPython 3
>> as it is more and more becoming the default in Linux distributions.
>> Anna has been quite active in trying to solve any specific wxPython3
>> issues.
>> On my Debian Testing system I have Python 2.7.8 and wxPython:
>> 3.0.1.1 and I do not see your error. So it would be interesting to
>> explore what happens on your system. What graphical environment are
>> you running in ? What does 'echo $SESSION_MANAGER' in a terminal
>> give you ?
>> Moritz
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150114/4ab105ae/attachment.html>
