[GRASS-dev] SESSION_MANAGER environment variable not defined
Anna Petrášová
kratochanna at gmail.com
Tue Jan 13 17:08:11 PST 2015
On Tue, Jan 13, 2015 at 6:21 PM, Andy Wickert <wickert at colorado.edu> wrote:
> Hi Markus and Moritz and all,
> Moritz -- Unity.
> Markus --
> Starting GRASS GIS...
> _IceTransOpen: Unable to Parse address 1
> 12:20:02 AM: Debug: Failed to connect to session manager: Could not open
> network socket
> So the blank "NetworkManager" in Unity is definitely the culprit in my
> mind.
just to make sure I understand, the gui opens (layer manager + window), but
adding map layer doesn't work? What else doesn't work? Do you get any other
error in the terminal or gui console? I just want to make sure there is no
other reason behind this. I was not really able to understand what the
weird error means by googling, but it seems that sometimes it could be
harmless.
Thanks,
Anna
> Andy
> Andrew D. Wickert
> INSTAAR & Geological Sciences, University of Colorado Boulder
> Now at:
> Universität Potsdam
> Institut für Erd- und Umweltwissenschaften
> Haus 29, Rm. 153
> Karl-Liebknecht-Str. 24-25
> 14476 Potsdam-Golm, Deutschland
> On Tue, Jan 13, 2015 at 2:29 PM, Moritz Lennert <
> mlennert at club.worldonline.be> wrote:
>> Are you using Unity ? GNOME ? KDE ? A session over ssh ?
>> I'm really no windows management and graphical environment expert, but
>> apparently some windows managers do not set this variable.
>> Moritz
>> On 13/01/15 13:02, Andy Wickert wrote:
>>> After the uninstall, I have:
>>> Python 2.7.8
>>> wxPython 2.8.12.1
>>> 'echo $SESSION_MANAGER' returns nothing both inside and outside the
>>> GRASS GIS environment in terminal.
>>> Andrew D. Wickert
>>> Now at:
>>> Universität Potsdam
>>> Haus 29, Rm. 153
>>> On Tue, Jan 13, 2015 at 11:50 AM, Moritz Lennert
>>> <mlennert at club.worldonline.be <mailto:mlennert at club.worldonline.be>>
>>> wrote:
>>> On 13/01/15 11:02, Andy Wickert wrote:
>>> Markus, you're a genius! I just tried starting the version of
>>> GRASS
>>> available on the apt repositories and got this message:
>>> awickert at dakib:~$ grass
>>> Cleaning up temporary files ...
>>> Starting GRASS ...
>>> ERROR: wxGUI does not support wxPython 3.0.0.0 yet.
>>> Error in GUI startup. If necessary, please
>>> report this error to the GRASS developers.
>>> Switching to text mode now.
>>> Hit RETURN to continue...
>>> So I think that what you are saying is that wxPython 3 somehow
>>> becomes
>>> the default / interferes with GRASS. I did:
>>> awickert at dakib:~$ sudo apt-get remove python-wxgtk3.0
>>> and now everything works. Well, hopefully my removal of wxPython
>>> 3
>>> doesn't break something else, so hm, is there a way to ensure
>>> that GRASS
>>> GIS always looks for wxPython 2?
>>> The idea is rather to try to solve any errors concerning wxPython 3
>>> as it is more and more becoming the default in Linux distributions.
>>> Anna has been quite active in trying to solve any specific wxPython3
>>> issues.
>>> On my Debian Testing system I have Python 2.7.8 and wxPython:
>>> 3.0.1.1 and I do not see your error. So it would be interesting to
>>> explore what happens on your system. What graphical environment are
>>> you running in ? What does 'echo $SESSION_MANAGER' in a terminal
>>> give you ?
>>> Moritz
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150113/74562fbf/attachment.html>
