[GRASS-dev] SESSION_MANAGER environment variable not defined
Martin Landa landa.martin at gmail.com
Wed Jan 14 00:31:15 PST 2015
2015-01-14 2:08 GMT+01:00 Anna Petrášová <kratochanna at gmail.com>:
>> _IceTransOpen: Unable to Parse address 1
>> 12:20:02 AM: Debug: Failed to connect to session manager: Could not open
>> network socket
>> So the blank "NetworkManager" in Unity is definitely the culprit in my
>> mind.
> Hi,
> just to make sure I understand, the gui opens (layer manager + window), but
> adding map layer doesn't work? What else doesn't work? Do you get any other
> error in the terminal or gui console? I just want to make sure there is no
> other reason behind this. I was not really able to understand what the weird
> error means by googling, but it seems that sometimes it could be harmless.
yesterday I switched to wxPython3 and I am getting this debug message
too when starting wxGUI...
01:16:47 AM: Debug: Failed to connect to session manager:
This debug message has no effect on my PC. Martin
Martin Landa
http://gismentors.eu/mentors/landa
