[GRASS-dev] SESSION_MANAGER environment variable not defined
Andy Wickert
wickert at colorado.edu
Wed Jan 14 01:29:31 PST 2015
Hi Anna and Martin,
Anna -- You are absolutely correct. What doesn't work is anything that
requires opening another window after GRASS GIS starts. No other errors
show up in the GUI console. This applies to the version that I compiled
myself. The version that I got from apt-get won't launch the GUI at all and
(as noted above) prints the following message:
ERROR: wxGUI does not support wxPython 3.0.0.0 yet.
Error in GUI startup. If necessary, please
report this error to the GRASS developers.
Switching to text mode now.
Martin -- just to double-check, did you try adding a layer and have success
in doing that? And what OS (and, if applicable, desktop) are you using?
Andy
Andrew D. Wickert
INSTAAR & Geological Sciences, University of Colorado Boulder
Now at:
Universität Potsdam
Institut für Erd- und Umweltwissenschaften
Haus 29, Rm. 153
Karl-Liebknecht-Str. 24-25
14476 Potsdam-Golm, Deutschland
On Wed, Jan 14, 2015 at 9:31 AM, Martin Landa <landa.martin at gmail.com>
wrote:
> Hi,
> 2015-01-14 2:08 GMT+01:00 Anna Petrášová <kratochanna at gmail.com>:
> >> _IceTransOpen: Unable to Parse address 1
> >> 12:20:02 AM: Debug: Failed to connect to session manager: Could not open
> >> network socket
> >> So the blank "NetworkManager" in Unity is definitely the culprit in my
> >> mind.
> > Hi,
> > just to make sure I understand, the gui opens (layer manager + window),
> but
> > adding map layer doesn't work? What else doesn't work? Do you get any
> other
> > error in the terminal or gui console? I just want to make sure there is
> no
> > other reason behind this. I was not really able to understand what the
> weird
> > error means by googling, but it seems that sometimes it could be
> harmless.
> yesterday I switched to wxPython3 and I am getting this debug message
> too when starting wxGUI...
> 01:16:47 AM: Debug: Failed to connect to session manager:
> This debug message has no effect on my PC. Martin
> Martin Landa
> http://gismentors.eu/mentors/landa
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150114/400d1e6a/attachment.html>
