[GRASS-dev] module header definitions add: text/multiline and latex support?
Pietro
peter.zamb at gmail.com
Wed Jan 14 02:59:58 PST 2015
On Wed, Jan 14, 2015 at 10:33 AM, Moritz Lennert
<mlennert at club.worldonline.be> wrote:
>> Do you think that would be possible to have a description option that
>> it does not take any input but allow us to be more descriptive inside
>> the module interface?
> If you add
> #% label
> and
> #% description
> the label will be displayed as text in the window and the description will
> be put into a tooltip that pops up at mouse-over. You can then put as much
> text as you want into the description.
mmh... do you mean inside the option?
I would like something outside the option, something before or after
an option, at the moment I have a GUI with the form:
Raster input map:
-> raster menu
Vector input map:
-> vector menu
I would like to be able to add a text/latex in the middle to make the
GUI self-explanatory and relay less on the manual page.
to have something like:
Raster input map:
-> raster menu
Add some more text here (just text/latex, not input is required by users)
Vector input map:
-> vector menu
