[GRASS-dev] g.remove GUI
Anna Petrášová
kratochanna at gmail.com
Thu Jan 15 18:24:19 PST 2015
On Thu, Jan 15, 2015 at 8:34 PM, Anna Petrášová <kratochanna at gmail.com>
wrote:
> On Thu, Jan 15, 2015 at 6:09 PM, Martin Landa <landa.martin at gmail.com>
> wrote:
>> 2015-01-15 22:26 GMT+01:00 Martin Landa <landa.martin at gmail.com>:
>> > 2015-01-15 14:03 GMT+01:00 Anna Petrášová <kratochanna at gmail.com>:
>> >> fixed in r64190,1
>> > thanks for the fix. Martin
>> what exactly it should fix? I tried g.remove GUI again (relbr70) and
>> there is still "No selectable element" regardless selected type...
> Interesting, before it was broken with both wxPython 2.8 and 3, now only
> with wxPython 3. I will look at it.
ok, should be fixed in r64210. The Select widget consist of comboctrl and
textctrl and the source of events has apparently changed. I already fixed a
couple of those but I am sure there are still a lot of bugs.
>> Martin
>> Martin Landa
>> http://geo.fsv.cvut.cz/gwiki/Landa
>> http://gismentors.eu/mentors/landa
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150115/a5c3bc00/attachment.html>
