On Fri, Jan 16, 2015 at 3:24 AM, Anna Petrášová <kratochanna at gmail.com> wrote: > ok, should be fixed in r64210. The Select widget consist of comboctrl and > textctrl and the source of events has apparently changed. I already fixed a > couple of those but I am sure there are still a lot of bugs. Thank you so much Anna for the quick fix! Pietro
