[GRASS-dev] Planning GRASS GIS 7.0.0RC1
Markus Neteler neteler at osgeo.org
Sun Jan 18 14:49:15 PST 2015
On Sat, Jan 17, 2015 at 10:21 PM, Vaclav Petras :
> On Sat, Jan 17, 2015 at 2:40 PM, Markus Metz  wrote:
>> I modified v.generalize in my local copy to become a topology
>> debugging tool. The debugging tools could be activated with an
>> environment variable which would need to be set by the test suite.
This sounds pretty cool to have.
> Setting environmental variable should be easy in the test suite. I'm not
> sure about the v.generalize modification. Topology debugging tool sound's
> generally useful. Perhaps it could be part of v.generalize interface or a
> standalone module (build with v.generalize in the same way as r.colors and
> r3.colors are) but for tests it really doesn't matter.
If that would be possible: perfect solution.
>> If I turn the tests into a test suite script, I will use a vector from
>> the the full version of the North Carolina sample dataset. Is this ok?
> This is ok. MarkusN says we should use the new dataset but I think it is not
> yet stable.
I would invite everybody to switch to these simplified names:
http://trac.osgeo.org/grass/wiki/SampleDataset
At page bottom download the dataset (done by Helena).
markusN
