[GRASS-dev] Planning GRASS GIS 7.0.0RC1
Vaclav Petras
wenzeslaus at gmail.com
Sat Jan 17 13:21:15 PST 2015
On Sat, Jan 17, 2015 at 2:40 PM, Markus Metz <markus.metz.giswork at gmail.com>
wrote:
> On Fri, Jan 16, 2015 at 11:25 PM, Vaclav Petras <wenzeslaus at gmail.com>
> wrote:
> > On Fri, Jan 16, 2015 at 10:01 AM, Markus Metz
> > <markus.metz.giswork at gmail.com> wrote:
> >> The fixes are all thoroughly tested (I guess I have never
> >> before tested vector topology so thoroughly...).
> > Hi Markus,
> > will you be able to turn your tests into testsuite scripts? It is
> additional
> > work but it gives us possibility to ensure that nobody will break what
> you
> > did and it should save it your time in the long run.
> I modified v.generalize in my local copy to become a topology
> debugging tool. The debugging tools could be activated with an
> environment variable which would need to be set by the test suite.
> Setting environmental variable should be easy in the test suite. I'm not
sure about the v.generalize modification. Topology debugging tool sound's
generally useful. Perhaps it could be part of v.generalize interface or a
standalone module (build with v.generalize in the same way as r.colors and
r3.colors are) but for tests it really doesn't matter.
If I turn the tests into a test suite script, I will use a vector from
> the the full version of the North Carolina sample dataset. Is this ok?
This is ok. MarkusN says we should use the new dataset but I think it is
not yet stable.
> > Let me know if you miss something in testing framework which would help
> you
> > to write the tests.
> I would like to provide a command and the test suite must check the
> return status. If someone else could then turn this into a testsuite
> script, that would be great!
> Any .sh or .py script you put to testsuite directory anywhere in GRASS
source code will be executed as test, so in your case, it should be enough
just to put the command to .sh file together with the appropriate export
command for the environmental variable. I'm afraid this feature is not
really documented (except for emails) because I did it in last minute and
it is not the best practice. Anyway, posting command is fine if the only
thing needed is to check return status.
Vaclav
Markus M
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150117/b73973dc/attachment.html>
